3D printing service Los Angeles, CA
FDM 3D Printing service in Los Angeles, CA
SLS 3D Printing service in Los Angeles, CA
MJF 3D Printing service in Los Angeles, CA
SLA 3D Printing service in Los Angeles, CA
Over 221 customers are satisfied with our 3D printing service.
“excellent. Well done, swift transaction. professional.”
hoyte, Los Angeles
Standard PETG, FDM
“Very happy with how this print turned out - awesome service, thanks! ”
Gary, Sherman Oaks
“Excellent communication, far more than I am used to!”
J., Los Angeles
“Great print and super-quick turnaround time!”
Jacob, Los Angeles
“Professional service, wonderful communication, and nice prints.”
Etamar, Van Nuys
“effortless, excellent. i got a reply immediately after submitting my order (on a holiday weekend no less!), and got the parts in no time. Every piece is perfect. Thank you!”
AE, North Hollywood
“Second time I order a part and its impeccable!”
Pavel, Los Angeles
Carbon filled Nylon, FDM
“He was very helpful, the prints came out great and he couldn't have been a cooler guy. Thanks again.”
Andrew, Burbank
“Trae communicated very well to me exactly how my product would look after being printed. He shipped fast too. Highly recommend!”
Gregory, Los Angeles
Standard ASA, FDM
“The print turned out perfectly, the turnaround time wast faster than expected, and communication was excellent. Highly recommend!!”
Karina, Culver City
“This hub was very accommodating. The parts are premium quality and were delivered early. Definitely will use this hub for future projects ”
Michael, Los Angeles
Clear resin, SLA/DLP
“Great communication, quick service and very good job! ++++”
Florence, Los Angeles
“Very flexible if you are looking to pickup a part”
Huzaifa, Los Angeles
Standard PETG, FDM
“Happy with the service. Arrived on time. ”
FARZAN, Burbank
“Great service, communication, and print quality!”
Joshua, Los Angeles
“Everything was expected and turnaround time was very fast.”
Charon, Los Angeles
“Great quality, price, and turnaround time!”
Andi, Los Angeles
“Super easy, explained everything and printed quickly ”
Oluwatobiloba, Los Angeles
“Thank you very much for the quick and perfect prints”
Biayna, Los Angeles
“Impeccable quality on my print. Communicated with me with great care and print was done swiftly and with no problems. Would definitely use this Hub again if I ever need another print. ”
steven, Los Angeles
Standard TPU, FDM
“Excellent service! Good quality prints on TPU for a prototype case (body and lid) for electronics. Fast shipping!”
Li, Los Angeles
Standard TPU, FDM
“Always good quality prints and quick feedback.”
Joanne, Los Angeles
“Good quality for our mock-up. Would consider future cooperation.”
Liang-Yu
“Insightful help, fast turn around, and excellent quality of my printed object.”
Scott
“Quick service and the product was also of good quality. ”
Swarochisa, Los Angeles
