3D printing service New York
FDM 3D Printing service in New York
SLS 3D Printing service in New York
MJF 3D Printing service in New York
SLA 3D Printing service in New York
Over 290 customers are satisfied with our 3D printing service.
“Great prints, great communication. Will use this seller again.”
Chad, Bushkill
“looks like the photos, was a tough print and will serve its purpose well”
Paul, Freehold
Standard PETG, FDM
“Just as expected. Fast delivery. No issues.”
frank, clarks summit
“Awesome service and great products. Couldnt ask for more.”
Danny, West Point
Standard resin, SLA/DLP
“Great job and shipped quickly. Item was received before quoted delivery date. ”
Mark, Flanders
“Service was quick, friendly and well done. will use in the future. ”
Joel, New City
“Quick and courteous,with high qualify results, I would definitely work with them again”
Alec, Ridgewood
“Very prompt communication, excellent print finish, met all my expectations.”
Vikas, woodclliff lake
Standard PETG, FDM
“The best 3D printing service in the world !”
John Paul, Croton-on-Hudson
“Always PERFECT Prints. I measure with calipers. Oh, and fast shipping. What more could you want? Best printer around!”
Michael, Croton-on-Hudson
“Print as expected. Communication and flexibility was excellent.”
Nelson, Florham Park
“Well packaged, on time, and got frequent updates.”
James, Paramus
“Outstanding quality and quick delivery, would order again any time. ”
Ed, Elmwood Park
“Great service. Communications and speed were exceptional.”
Richard, West Orange
Standard ASA, FDM
“Arrived quickly with updates throughout the process, exactly as requested.”
Rob, Endwell
Standard TPU, FDM
“My order was printed and shipped quickly. Excellent service and communication.”
Martin, Wallington
Standard ASA, FDM
“I ordered a print at the cheapest level and the quality is much better than I anticipated. These guys examined my drawings in no time, got the print started, snapped images post-print, and got it out the door in the same day. A+ service.”
Valentino, Easton
“Great part, works and fits exactly as i needed”
Justice, Utica
“Excellent service. Great person. Very helpful. Quality work!!!”
Yinka, Irvington
“Perfect. Prints were started the day of upload and delivered before the deadline. Quality is near perfect! ”
Bryan, Kearny
“Great communication and custom part fit perfectly. Thanks! ”
Michael, Union City
“Always a wonderful experience and perfect print. Thank you!”
Sue, BETHLEHEM
“Fast turnaround, quality print, good price.”
Brian, New York
“Very quick and professional. Will buy from again. ”
Chris, New York
“Great communication and printed parts looked great. Highly recommend!”
Mark, New York
