3D printing service Oklahoma City, OK
FDM 3D Printing service in Oklahoma City, OK
SLS 3D Printing service in Oklahoma City, OK
MJF 3D Printing service in Oklahoma City, OK
SLA 3D Printing service in Oklahoma City, OK
Over 156 customers are satisfied with our 3D printing service.
“Great suggestion & quality. Will re-order with them again”
Bryn, Oklahoma City
“Great prints, thank you. There will be more.”
chad, Oklahoma City
Standard Nylon, SLS
“Superfast delivery! I received the order in two days it was submitted! Great quality as well. ”
Ravi, OKLAHOMA CITY
“Incredible service and great quality. Highly impressed!”
steve, moore
“Excellent! Will use service again - Thanks!”
Aaron, Norman
Standard TPU, FDM
“Amazing work, service, speed, and communication!”
Kyle, Ada
“uploading the files and sending in the order was very simple and my order was sent out and delivered faster than i expected ”
Jesse, Glenpool
“Fantastic Service provider. Answered questions, good quality prints, offered suggestions! Looking forward to working with him in the future.”
Todd, JENKS
Standard ASA, FDM
“Thank you very much! Everything turned out as expected! ”
Patrick, Broken Arrow
“Awesome Service i will definitely be using it again!”
Ahmad, Sherman
“Good quality print, fantastic costumer service, fast shipping. Pleasure to do business.”
Sam, Derby
“Great service. Even suggested other colors for my project. Excellent customer service:)”
Walter, Alvord
“Very friendly, accommodating and quick! Parts were perfect! Couldn't have asked for a better experience!”
Zachary, Wichita
“I keep coming back. Great service and products as usual.”
Matthew, Wichita
Carbon filled Nylon, FDM
“Great experience! Will be back for future projects! ”
Nathan
“Very professional, parts were printed nearly instantly and constant communication was maintained.”
Ian, Denton
“Very happy with the quality of the printing job and the shipping. Would like to use again in the future.”
Jason, McKinney
Standard Nylon, SLS
“Thanks for being flexible with the pickup time.”
Nate
“You guys worked on the weekend, listened to my needs, gave great advice and got my print before my event!! Couldn't have been any better. Excellent.”
Robert
Standard resin, SLA/DLP
“Fantastic service and print came out better than expected.”
Katie
“Prints came out very nice, as expected, and they served their purpose.”
Enrique
“Robert was amazingly fast, parts are great.”
Jim
“Good service and value. Planning to come back.”
Leming
“Great communication, good quality print at a solid price point with excellent turnaround time.”
John
Standard Nylon, SLS
“FANTASTIC experience as always. Always nice to be a return customer. Will be back again!”
Matt
